Cam Chain Tensioner problem - Page 3 - Kawasaki ZX-10R.net
 5Likes
post #21 of 26 Old 03-21-2017, 12:52 AM
EJR
EJR's Avatar
Yeah, I was thinking valve adjustments on cylinder 4. Really though, the camshaft gears are marked on the outside with either an IN (intake) or EX (exaust). The markings are facing the frame, so you may have to use a mirror to see them with a flashlight. In the manual it will tell you the position these markings (they are underlined on the gear itself) they have to be in relative to the top of the head when set to 1/4 on the timing gear. In other words, you set the timimg gear to 1/4, and place the camshafts in the head so that the underlined IN and EX underlines are parallel to the top of the head. This will ensure you never screw the timing and is a good sanity check after you are done adjusting valves etc.
EJR is offline
post #22 of 26 Old 03-21-2017, 01:08 AM
Originally Posted by bun1t View Post
This is correct. The new part number is similar to the Gen 4 style CCT. They said the original 16 style was putting too much tension on the chain.
That does not make any sense. Your dealer lied to you - much like mine does.
If the tensioner was placing too much pressure on the cam chain you would not hear the BB's in a box sound, instead you would hear a whirring noise. The reason people hear the BB's in a box is because the cam chain does not have enough pressure on it an it is slapping around, like a red light district wet noodle.
Gen-Eric is offline
post #23 of 26 Old 05-07-2017, 06:22 PM
My Gen5 has 3k miles and it's starting to sound a little bit. My friends gen5 it's been to the dealership 3 times for the same noise.
Cabilloabajo is offline
post #24 of 26 Old 05-07-2017, 09:01 PM
Mine 2016 was quite bad, started around 500 miles on the clock. Got an APE manual tensioner. Definitely worth the 90$.
th3r3ds0x is offline
post #25 of 26 Old 05-08-2017, 04:35 AM
Thanks
post #26 of 26 Old 05-08-2017, 05:09 PM
lukky14's Avatar
Kawi did the recall on my 16 a few weeks ago, swapped out the manual for automatic. At first it was still noisy, but after a ride it seemed to do it's job and not nearly as noisy anymore.
Sent from my SM-N920V using Tapatalk
lukky14 is offline
Tags
2016 zx10r, cam chain
