Gen 5: 2016 -> Brembo Rear Caliper - Page 2 - Kawasaki ZX-10R.net
 13Likes
post #11 of 16 Old 05-08-2018, 11:23 AM
This my rear brake set up from the UK.
L74 do some nice quick release kits using Lightech chain adjusters.
ddipaola likes this.
10rAlex is offline
post #12 of 16 Old 05-08-2018, 02:16 PM Thread Starter
ddipaola's Avatar
Why do they opt for an upside down caliper? Don't you want a slight angle for bleeding and air bubbles?
When in doubt... send it!
ddipaola is offline
post #13 of 16 Old 05-08-2018, 03:45 PM
SkyDork's Avatar
Underslung calipers are make for faster wheel changes and the caliper is pulled rather than pushed when under tension. There are mechanical advantages and it has nothing to do with bubbles and bleeding. There shouldn't be any air in there to generate bubbles anyway.
Also, the rear caliper is useless when the rear wheel is in the air! Go ahead and put one of them fancy Brembos on the rear and stomp on it! Or, just properly use the front brake and forget about the rear altogether.
#WordCrimes
SkyDork is offline
post #14 of 16 Old 05-08-2018, 03:49 PM
Post Whore
Older Guy's Avatar
When I took Keith Codes California Superbike School, they a drill where you had to get the track and just use shifting.....no braking allowed anywhere on the circuit...was a good drill...
Older Guy is offline
post #15 of 16 Old 05-08-2018, 08:52 PM
Gen 5 Now!!
08zx10rny's Avatar
I really just did it for tire changes. I was using the Fast Franks caliper holder with stock caliper but the caliper was getting caught up on the rear wheel trying to remove it, scratching the rim constantly. This Brembo caliper is the cheapy one thats on comes stock on the RSV4RR. Nothing fancy like the billet calipers that are $900. But I do use the rear brake to change my lines track riding and racing.
GEN 5!!!
08zx10rny is offline
post #16 of 16 Old 05-08-2018, 09:03 PM
Gen 5 Now!!
08zx10rny's Avatar
i really didnt secure it with anything other than it clipped to the rear wheel speed sensor. I used a Spiegler Non-ABS rear line and just reversed the line from how normal installation is. The banjo on the caliper now has a slight pitch away from the wheel and is perfect length.
Originally Posted by JLG0987 View Post
Can you post a picture of the brake line routing from behind? I'd like to see how you secured it
GEN 5!!!
