Hi just wondering, I did the PIA job to get to the pair valve and removed then installed block off plates,
Well I installed the block off plates without re-installing the read valve assembly and that gasket, ok has anyone did this,
I mean I blocked off the hose to the airbox, someone said I can get an air leak,
my question, ok if I get a tiny leak what impact would this have it is in the exhaust side, I removed the O2 sensor, plugged the evap canister.
anyone intall blockoff plates with out the reed valve
