Gen 5: 2016 -> Autotune Info - Kawasaki ZX-10R.net
 14Likes
post #1 of 19 Old 05-31-2018, 08:50 AM Thread Starter
ddipaola's Avatar
Autotune Info
Can you run auto-tune on an ECU that's been re-flashed? I know when you send an ECU off to be re-flashed whatever info that's on there is not accessible to the user. Does that mean that I would not be able to run autotune since the fuel map will be locked?
When in doubt... send it!
ddipaola is offline
post #2 of 19 Old 05-31-2018, 10:16 AM
SkyDork's Avatar
The answer is...maybe.
If you're trying to auto-tune everything through the ECU, then no. That's not the way it works. If you're using a piggyback box to alter the fueling slightly after the commands leave the ECU, it doesn't matter what the flashed code in the ECU does.
#WordCrimes
SkyDork is offline
post #3 of 19 Old 05-31-2018, 11:08 AM
FTECU ActiveTune in Live Correction Mode will modify AFR in real time with any FTECU map. If Live Correction mode is disabled, you cannot save the logged trims on a locked FTECU map. You can save the logged trims on an unlocked FTECU map. If you are not using an FTECU map, then I have no idea. You'd need to contact Flash Tune.
ddipaola likes this.
GearsNStuff is offline
post #4 of 19 Old 05-31-2018, 11:56 AM Thread Starter
ddipaola's Avatar
Sounds like the ECU is locked down then.
Would the "read ECU" button on the FT software, to extract the tune, basically give me nothing or error-out then?
Don't want to press the read button if it's gonna screw something up or resets it
ddipaola is offline
post #5 of 19 Old 05-31-2018, 01:54 PM
bun1t's Avatar
Have you considered just riding the bike instead of tuning it over and over again?
bun1t is offline
post #6 of 19 Old 05-31-2018, 02:16 PM
Should be able to read it, but it will still be locked, i.e. you won't see the stuff that's locked.
Just want to add that the Bosch wideband sensor lasts about 10,000 miles - unsure if that means you need a new one at 10,000, or it needs calibrated. The 10,000 figure came directly from FTECU support. FTECU sells the Bosch sensor individually should you ever need a new one.
post #7 of 19 Old 05-31-2018, 08:37 PM Thread Starter
ddipaola's Avatar
That's why I have more than 1 bike!
GearsNStuff likes this.
ddipaola is offline
post #8 of 19 Old 06-02-2018, 04:08 PM
The Pace
scout's Avatar
No reason to auto whatever on this bike. Flash is total waste, too. ivan's wire thing is interesting.
scout is offline
post #9 of 19 Old 06-02-2018, 09:42 PM
speed_freak91's Avatar
I still to this day can't decide if you're an epic troll or serious about the stuff you say...
michael4012 and ddipaola like this.
speed_freak91 is offline
post #10 of 19 Old 06-03-2018, 08:12 AM
Victors's Avatar
Hes serious. Which makes him the worst troll of all.
michael4012 likes this.
2013 10R
2007 650R
2016 10R
Victors is offline
