Gen 4: 2011-2015 Anyone have some suspension geometry advice - Page 7 - Kawasaki ZX-10R.net
 27Likes
post #61 of 68 Old 03-09-2017, 03:33 PM
tdh
tdh's Avatar
The "F" and the "S" marks on my adjusters are for if you are "fat" or "skinny" right?
sdiver68 likes this.
tdh is offline
post #62 of 68 Old 03-09-2017, 07:45 PM
moto316's Avatar
Originally Posted by sdiver68 View Post
@moto316
Those numbers are with an aftermarket shock link...right? If I'm reading these correctly they want you to raise the front 5mm and the rear 2mm?? More explanation is required...if I'm reading this right it could be a very slow and heavy turning bike. Although it should be a rocket on acceleration if your style is to square off corners like Sykes.
Yes a MSS type 3 link. Running k-tech 25 rds cartridges which my tuner said added some travel compared to the stock forks so the ride height numbers are a little skewed if you're trying to compare numbers.
moto316 is offline
post #63 of 68 Old 03-09-2017, 08:25 PM
sdiver68's Avatar
Originally Posted by LDH View Post
There are many ways to skin that cat...
Many of the pro guys on the Gen4 were raising both the rear and the front and use less than traditional sag numbers as well which also keeps the front riding high requiring or reacting to heavy loading to make it handle correctly. Along with that though they are also using Gas Fork Kits which have a very small window of operation and a finely tuned spring rate through both the coil and the air spring so that it sets the front end consistently on maximum trailbraking allowing the geometry of the bike to assist the rider both into and out of the turns. These are the guys running at or near the lap record and that is how they achieve those results.
Even 2 different Pro riders at the limit with same lap times riding the same model bike still require different set-ups based on their riding styles. What works for one rider does not automatically work for another, but the further you are off the pace the further you can be off the optimal setting and still get a good handling ride.
Agreed, many ways to skin that cat. I'll let you in on rule #3 of Lessons Learned the Hard Way racing motorcycles:
3) Because you saw it done by a Pro or on a Pro bike means no more to you then trying to dunk from the free throw line because that's what Jordan did.
tdh likes this.
Thank you to my racing sponsors Riders Discount and Alpha1 Vinylworks
sdiver68 is offline
post #64 of 68 Old 03-10-2017, 04:40 AM
Carlos76's Avatar
How much fork tube above top clamp was there at time of measurement?
Your sheet shows 8 N/mm topout springs, from factory RDS and DDS should be 4N/mm.
Is that a typo or was it upgraded to 8N/mm (very stiff).
And would you measure length of visible chome tube with specified 8mm preload, then we can use your numbers.
Take two measurements, both sides of sticktion, one after forks were compessed and second after you extended forks by pulling up and releasing gently.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
post #65 of 68 Old 03-20-2017, 06:01 AM
Carlos76's Avatar
Bling.
My adjustable triples arrived finally.
Will report how steering feels with 30mm offset in 4 weeks.
horra and ukzx10r like this.
Carlos76 is offline
post #66 of 68 Old 03-25-2017, 06:06 PM
I made a few tweaks to mine today.
Raised rear end 6mm.
Slipped forks through 3mm.
4 clicks less on rear shock rebound to try stop rear end from squatting under load.
Verdict is im not sure .
Its so hard to tell from road riding if its better but it seemed to wheelie less but prehaps be a little unsetteled at the front under braking.
Possibly due to the change in geomatory.
But this was only noticable on slower speed corners so once on track it may be a different story
ukzx10r is offline
post #67 of 68 Old 04-18-2017, 09:35 AM
Carlos76's Avatar
My first time out after winter. No other geometry or suspension changes except clamp offset from stock 26mm to aftermarket 30mm.
Change in steering was more than I expected: much less force needed to lean bike quickly, bike feels much lighter, maybe precision hitting curb exactly is less (difficult to say after winter pause) and good thing: it did not cause instability at hard braking.
I will have to try 28mm excentric too, because steering is possibly too light now and have to be real precise with hands to select racing lines. Have to do more riding to judge this investment, but my first impression says: "significant change in how bike reacts to steering input".
LDH likes this.
Carlos76 is offline
post #68 of 68 Old 06-07-2017, 12:34 PM Thread Starter
So been reading more into how geometry affects bike handling, and I wanted to see what Kawasaki changed from past iterations of the ZX10R
Specifically, I looked at the original 04 machine as it was known for it's flighty nature, due in part to a relatively short wheelbase (I heard that the chassis was based on a 250 GP race bike but not sure about that).
I've never ridden an 04 but I figured the 2011 is quite the opposite of this so I looked at some specs between the two.
2004
Rake: 24 degrees
Trail: 102 mm
WBase: 1385 mm
2011
Rake: 25 degrees
Trail: 107 mm
WBase: 1425 mm
Looking back at evallarta1's post near the beginning of this thread, you can see that the final rake and trail numbers he posted (23.6 degrees and 103 mm respectively) are close to that of 2004 stock geometry.
The big difference is in wheelbase which he had as 1422 mm, as opposed to 1385 mm on the 2004.
To me the gen 4 ZX10R feels very stable at the front and it's not too difficult to turn (no race track experience with this bike yet though), but definitely more input required than other litres I've owned.
Not wanting to change front end stability too much, when I start prepping the bike for track, I was thinking to play with shortening the wheelbase slightly first, rather than changing front rake and trail.
I know this will make the bike more wheelie prone, but will this introduce agility and keep some of the front end stability on the brakes and in the turn?
10Arghh is offline
