Gen 5: 2016 -> Anyone have any issues with gen5 low dyno numbers? - Page 6 - Kawasaki ZX-10R.net
 9Likes
post #51 of 66 Old 10-10-2017, 10:55 AM
bun1t's Avatar
Who flashed it? I've had multiple Gen 4's and 5's on the dyno and I have yet to see a Gen 5 make less hp than a 4. Usually a 5-6hp difference on pump gas.
bun1t is offline
post #52 of 66 Old 10-10-2017, 11:15 AM Thread Starter
Victors's Avatar
I did
2013 10R
2007 650R
2016 10R
Victors is offline
post #53 of 66 Old 10-10-2017, 12:39 PM
bun1t's Avatar
Originally Posted by Victors View Post
I did
ETV Open all the way?
bun1t is offline
post #54 of 66 Old 10-10-2017, 02:05 PM
SpazOnaZX's Avatar
You'd be remiss not to do a compression and leak down test on it and compare it to a known sample (preferably one of those similar bikes that is up on power).
In addition to that, you could run a fun little experiment: put stronger clutch springs in there. It's cheap and easy to do, and I've seen it yield measurable performance gains more often than it does not. ;)
realpsi and Victors like this.
SpazOnaZX is offline
post #55 of 66 Old 10-10-2017, 06:49 PM Thread Starter
Victors's Avatar
Set at 100 yes..
2013 10R
2007 650R
2016 10R
Victors is offline
post #56 of 66 Old 10-12-2017, 08:18 AM
mpp12's Avatar
did the dyno run.... the client did not want a base run, he just wanted to have the bike tuned...
before was a gen4.. piece of crap 175, a gsxr 1000 2013 170 after reflash and tune, then he got 198hp, then I wanted to test some things on my bike gen4 (not stock) did 192.
mpp12 is offline
post #57 of 66 Old 10-12-2017, 09:25 AM Thread Starter
Victors's Avatar
I'm assuming you started with a de-restriction run first.. So where did the 5th gen start for power before yuou finished tuning?
What mods did it have?
Mind if I ask What You did for total timing at 100% throttle?
Oh.. And what fuel?
2013 10R
2007 650R
2016 10R
Victors is offline
post #58 of 66 Old 10-12-2017, 09:40 AM
mpp12's Avatar
victors, unfortunately I have to satisfy clients first, then satisfy my curiosity later...
I did not touch the timing since the timing was OK at 32 on the top end... usually gen4, I use 32 and in my bike 31.
bike had filter (bmc) and a decat slip on.
normal fuel from pump 93.
to give you an idea, on that dyno.... brentune, full exh bmw 16 makes 191, a panigale 1299 stock 178, reflash 197 reving the shit out of the pani. (I was shiting myself reving +1000 rpm and that bike kept making power.)
I you want
email me.
motoseteo@gmail.com
Can send you the pics of the maps I used.... no secrets here in this forum.
mpp12 is offline
post #59 of 66 Old 10-12-2017, 11:37 AM Thread Starter
Victors's Avatar
I you want
email me.
motoseteo@gmail.com
Thanks man.. sending you an email now
2013 10R
2007 650R
2016 10R
Victors is offline
post #60 of 66 Old 10-12-2017, 11:53 AM
mpp12's Avatar
ok, when I get home..
mpp12 is offline
