Gen 5: 2016 -> Anyone have any issues with gen5 low dyno numbers? - Page 3 - Kawasaki ZX-10R.net
 9Likes
post #21 of 66 Old 09-28-2017, 03:25 PM
peterd10r's Avatar
Images: 7
Originally Posted by Victors View Post
Did you not read a single thing I've said in this entire thread?
Okay, I gotta request that you no longer respond to any thing I'm the original poster on again. I'm not joking. You never really contribute in any meaningful way and all you do is get me irritated. Thanks buddy.
Hi Victors!please don't take Scout to serious because I can assure you he means no harm!insult or disrespect!his views sometimes can confuse but that's just Scout and the way he words things!honestly in time his comments will actually humour you!Im 100% sure he is not out to hurt!belittle or insult anyone on the forum!
Thanks mate
Peter
Sent from my iPad using Tapatalk
peterd10r is offline
post #22 of 66 Old 09-28-2017, 03:28 PM
nakedinseattle's Avatar
Who did your flash and also, no restrictions isn't the same as flashed with a tune for that 3/4 exhaust. Improper flash can be a lot of it.
Shut up and ride.
Nun sacciu, nun vidi, nun ceru e si ceru durmiv
nakedinseattle is offline
post #23 of 66 Old 09-28-2017, 03:37 PM
I, personally, wouldn't use full synthetic until the 1000 mile mark minimum. I also wouldn't have changed the oil so early. Those metal shavings are needed to help wear everything in for the first 5-600 miles. You can check my post on my ZX-10RR and see the power I am making. I changed the oil at 600 miles and am still on mineral oil at 1200 miles. The engine will make more power as the break in period goes on, but it shouldn't be a drastic change. I got the 10RR after I totaled my gen 5 10r, and the RR makes maybe 6-8 hp more when fully dyno tuned.
frickenmoron is offline
post #24 of 66 Old 09-28-2017, 04:04 PM Thread Starter
Victors's Avatar
Thanks mate
Peter
Nope, cant do it. I've been here a few years now. Just can't anymore. From telling people that flashing doesn't make any more power to the other nonsense that he posts... I'm done. It's cool that you're backing him up and I know many others do as well, but I just can't. He's flat out given people incorrect info and it could cost someone eventually.
Woolich.. when I get some real dyno time i will be doing the tuning myself. I'm more than capable and tune on the side. This was just a shootout and the first and only time this bike has been on the dyno.
Don't these bikes come with synthetic from the factory?
2013 10R
2007 650R
2016 10R
Victors is offline
post #25 of 66 Old 09-28-2017, 04:13 PM
No sir, they come with MO from the factory. I continued MO after the first oil change, but my next change will be to full synthetic. Unfortunately full synthetic doesn't allow the pistons to wear against the cylinder walls enough for break-in which is why it shouldn't be used until break in is finished.
post #26 of 66 Old 09-28-2017, 05:01 PM Thread Starter
Victors's Avatar
I've never been one to believe in that stuff.. but screw it. I'll swap in some regular and see what happens.
2013 10R
2007 650R
2016 10R
Victors is offline
post #27 of 66 Old 09-28-2017, 05:32 PM
Ya, it can't hurt anything. Just make sure you ride normally and your ecu is fully derestricted, and you'll see it make a lot of power after you get rid of the cat. Keep us posted on your gains!
post #28 of 66 Old 09-28-2017, 06:08 PM
Also, have you checked for blow-by? Are you losing any oil between changes?
post #29 of 66 Old 09-28-2017, 06:40 PM Thread Starter
Victors's Avatar
Cats off.. graves 3/4.. hence why I'm even more concerned about power.
2013 10R
2007 650R
2016 10R
Victors is offline
post #30 of 66 Old 09-28-2017, 06:41 PM Thread Starter
Victors's Avatar
No, haven't checked. Doesn't appear to be an issue based on my levels so far.
2013 10R
2007 650R
2016 10R
Victors is offline
