Another Gen 3 headed for the strip - Page 4 - Kawasaki ZX-10R.net
 12Likes
post #31 of 128 Old 02-15-2016, 02:32 AM Thread Starter
Just ordered up the necessaries for the rear: extensions, 150 link chain, brake line and lowering link and o2 sensor bung for the wideband commander. Next up will be to address the front end by way of lowering straps and brocks radial mount brackets, then down size the counter shaft for a 16 and get a variety of rear sprockets.
Brock and gazx10 like this.
'08 10R, Lime/Black
Flashed ECU, PC5,WBC, custom shift light, shifter w/co2, cat delete, V&H slip-on, BMC race, lowered, stretched,-2/+5
MORE TO COME
medicbaldwin is offline
post #32 of 128 Old 02-20-2016, 02:42 PM Thread Starter
Got most of the parts. So far so good. Question for you guys. Is there a way to install the lowering links without having to suspend/hang the bike in the air? If that's what I have to do, is there a way to do it without taking the tail off and running a strap around the frame and using a hoist to hold it?
'08 10R, Lime/Black
MORE TO COME
post #33 of 128 Old 02-20-2016, 03:19 PM
thundercoupe9's Avatar
I used a jack to jack the bike up and then put 2 jack stands under rear sets......that's about it.
thundercoupe9 is offline
post #34 of 128 Old 02-22-2016, 12:37 AM Thread Starter
sounds easy enough. Thanks for the info Thunder. That clutch basket is still sitting in the box, waiting for the clutch and Brock's cushion kit, then it'll go in. Sure looks good though, ha ha
'08 10R, Lime/Black
MORE TO COME
post #35 of 128 Old 02-22-2016, 02:26 AM
YOu don't need a clutch mod, all you need is a gen1 clutch, that's it.
post #36 of 128 Old 02-23-2016, 01:49 AM Thread Starter
Will the gen 1 clutch setup will fit straight into the basket I bought from you, no need to modify anything? Do you recommend a gen1 drag pak setup from cycle conepts or a gen1 OE kawi clutch setup?
Do the gen1 springs have a higher clamping force or will I need a set of heavy duty springs to go along with it?
'08 10R, Lime/Black
MORE TO COME
post #37 of 128 Old 02-23-2016, 02:43 AM
You're really only after 1st gen judder spring plate. You put it instead of the 06+ zx10r judder spring and correct the height of the stack with correct thickness steels, that's really it. Clutch springs probably didn't change much, it really depends on the total mass of the bike/rider, gearing and torque that the engine produces. The heavier the rider/bike, the taller the gearing, if the engine makes more torque = will need more spring pressure on the clutch. I didn't have any problems with stock springs, but I did end up putting 3 heavier springs later on, it made no difference what so ever.
post #38 of 128 Old 02-24-2016, 08:14 AM Thread Starter
With this judder spring you speak of, is that something that would typically come in a clutch replacement kit or will I need to order a judder spring in addition to the clutch kit?
'08 10R, Lime/Black
MORE TO COME
post #39 of 128 Old 02-24-2016, 10:26 AM
zx racer's Avatar
Dewayne at cycle concepts sells the 1st gen dragpak with or without the judder spring.
05 ZX-10R SWB.
zx racer is offline
post #40 of 128 Old 02-24-2016, 07:35 PM
If you order the 1st gen clutch, you should get the judder spring. But you can also order just a judder spring and use your factory clutch and just order correct steels to get correct stack height.
