So i have ebc friction plates, ebc springs and barnett plates for a set up. Been running strong for the 5000kms i have had them installed. Last few days it started slipping bad in first ans second gear. Adjusted the cable on the clutch end, felt good for abit then got worse. Weird thing is it would slip first and second gear but wont slip in higher gear with low rpm but high load. In any case i pulled the pack out, no scorch marks. Put it back in and its running like a chanp. Any idea wtf happened?
Started slipping again. Fml. So now im really confused. No scorch marks so one would think the stack height is off slightly. But if thats the case, why now? Why after 5000kms?
Wondering if thats the key, i used motul 300v since i installed it. Worked fine. Switched back to kawis full synth and ever since then it started slipping. Wondering if its to late to switch back to motul 300v to see if that solves the issue
Related Threads
Kawasaki ZX-10R Forum
2.1M posts
128.9K members
Since 2003
