Gen 4: 2011-2015 abs removal - Page 5 - Kawasaki ZX-10R.net
 11Likes
post #41 of 104 Old 12-05-2014, 08:52 AM
Sorry, got tied up with some projects at work as well as playing with some new toys :)
Here are the scans:
And I'm guessing they may not show up or be the best, so here is a larger PDF version:
https://dl.dropboxusercontent.com/u/...Comparison.pdf
ZX10RArcher is offline
post #42 of 104 Old 12-08-2014, 10:31 AM
Turbodc2's Avatar
Just out of curiosity why not just buy a non ABS bike? Did they stop making them without it? Seems a little pointless to buy the ABS model and pay more just to rip it out?
For track riding I'd for sure want NON ABS, but for street riding, I definitely want it. I guess that's just my opinion though. Maybe on the Gen 5 we can get a threshold selector for normal, rain, track, off.
'94 EX500r: SOLD
'08 SV650s: SOLD
'11 GSX-R750: SOLD
'12 ZX10R: TOTALED
'12 ZX10R: current
'05 GSX-R600: Track.
'12 ZX-10R: woodcraft frame sliders, techspec tank pads, Guhl reflash, Graves full SS exhaust, zero gravity seat, motodynamic integrated rear turn signals, shock rebuilt by velocity calibrations with race tech internals and spring, bazzaz qs4, ZFI. and dyno tune.
Turbodc2 is offline
post #43 of 104 Old 12-08-2014, 10:44 AM
LDH
LDH's Avatar
I purchased my Gen 4 as a track only bike. Couldn't afford a new one so I bought used and the deal too good to pass up that came along was an ABS model so my only choice was to disable and/or remove the system.
Luckily I know how to ride on the street as well as the track so I don't need ABS for either.
LDH is offline
post #44 of 104 Old 12-08-2014, 10:53 AM
Turbodc2's Avatar
Ah gotcha. Good for you. Hope it keeps working out for you.
'94 EX500r: SOLD
'08 SV650s: SOLD
'11 GSX-R750: SOLD
'12 ZX10R: TOTALED
'12 ZX10R: current
Turbodc2 is offline
post #45 of 104 Old 12-09-2014, 09:24 AM
bun1t's Avatar
This.
I got a deal on mine as well
bun1t is offline
post #46 of 104 Old 03-02-2015, 09:24 AM
Baddie's Avatar
Just FYI on a 2012 model:
I removed all the ABS lines & fittings from the bike, but left the ABS block still plugged into its harness. I then ran aftermarket brake lines direct from the master cylinders to the calipers and with both ABS fuses still installed the ECU doesn't even know the difference. When I start the bike the ABS light comes on just like normal and as soon as I start to roll the ABS light goes off.
I'm trying this on Sat finger cross it works on My EU model.
Ripping all the OEM brakes lines out and installing HEL brake lines.
Baddie is offline
post #47 of 104 Old 03-02-2015, 02:46 PM
peterd10r's Avatar
Images: 7
Baddie rip the old out! Block lines from abs unit! You can remove the rear line inside the swingarm without removing the swingarm! You will get NO faults lights...mine is Aussie as yours
peterd10r is online now
post #48 of 104 Old 03-02-2015, 03:10 PM
White Fang's Avatar
Yes.
White Fang is offline
post #49 of 104 Old 03-04-2015, 05:13 AM
Baddie's Avatar
Mate what did you use to block holes with. ?
Baddie is offline
post #50 of 104 Old 03-04-2015, 07:08 AM
TurboR1's Avatar
Two ways you can block the holes... allen key grub screws of the correct thread (obviously), I filled mine up with silicon sealant, you'll need to make sure all the fluid is gone or it won't adhere to the block.
TurboR1 is offline
