7whp gain with E85 - Kawasaki ZX-10R.net
post #1 of 7 Old 08-26-2017, 01:55 PM Thread Starter
bun1t's Avatar
7whp gain with E85
bun1t is offline
post #2 of 7 Old 08-26-2017, 02:01 PM
Not bad, Is that from 93?
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is offline
post #3 of 7 Old 08-26-2017, 02:04 PM Thread Starter
bun1t's Avatar
Yes from 93 octane.
Interestingly enough, I had a Gen 5 on the dyno the next day and we only picked up 7whp with MR12.
bun1t is offline
post #4 of 7 Old 08-26-2017, 06:21 PM
How did you add the extra fuel? All on the top injectors? Fuel pump adequate?
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is offline
post #5 of 7 Old 08-27-2017, 11:58 AM
PatrickG's Avatar
Images: 15
Been running it for 2 seasons now on dragbike. It blows people's mind when you tell them it's on e85. Did you do an actual test to see how much ethanol was in it. Local summer blend here is about 90-91%.
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #6 of 7 Old 08-27-2017, 03:49 PM Thread Starter
bun1t's Avatar
I split the injector load on the top end so it doesn't push one set of injectors too hard. The pump seems to be handling it, we'll see. I have tuned a couple ZX14'S for E85 and I wasn't able to split the injector load but the injectors didn't seem to have an issue.
Yep, that's my next step. I'm curious what the actual ethanol content is.
bun1t is offline
post #7 of 7 Old 08-27-2017, 06:05 PM
MPac's Avatar
You've got my attention
MPac is offline
