Gen 1: 2004-2005 636 linkages on a 10? - Page 2 - Kawasaki ZX-10R.net
 2Likes
post #11 of 22 Old 06-08-2015, 04:11 PM Thread Starter
OK. So finally got around to fitting the 636 linkage to the rear of my 10. Straight from the off I can feel that the OE spring now travels more so I needed to completely reset the rider sag, I deffo need the stiffer spring ;)
On the road the bike is more forgiving, so I have also changed my rebound and comp settings to suit. A little more rebound as I the spring is set shorter to achieve the same sag, it is set so it 'just' holds the spring when releasing. Also a turn more comp damping. I got a little bit squiggly out of a turn before this change.
I only have 5 miles or so under my belt with the new links and settings so will have to see how it goes. First impressions, a change worth trying as I always felt the rear was WAY to stiff.
Bearings are all interchangeable, this was the hold up before but managed to swap the bearings from another spare that I had.
Bluey is offline
post #12 of 22 Old 06-09-2015, 01:44 AM
blink.'s Avatar
Originally Posted by 880turbo View Post
That was a common mod for Gen 1 bikes. A lot of the track guys did it. I did that mod on my Gen 1, and I thought it made a very nice improvement. You need to change both the knuckle, and the 2 linkage arms together. I think I still have the setup that I ran on my Gen 1 if anybody wants it. It is a direct bolt on. Mike.
How much? It's something I've been interested in doing...
blink. is offline
post #13 of 22 Old 06-11-2015, 05:43 PM Thread Starter
I now have lots of time on the new set up and I like it. Power on sooner out of the corner ;)
Bluey is offline
post #14 of 22 Old 06-11-2015, 08:12 PM
Blink; If you want the whole setup, how about 30 bucks? Let me know. Mike.
880turbo is offline
post #15 of 22 Old 06-15-2015, 03:32 PM Thread Starter
Liking this mod so far. ;)
I still have confidence in the corners, no change there. The mod has just helped to soak up some of the bumps. Knee down still easy.
Bluey is offline
post #16 of 22 Old 06-19-2015, 09:33 AM
TrickKwak's Avatar
Glat it all worked out alright for you Bluey! Thanks for the feedback.
2005 ZX-10r
TrickKwak is offline
post #17 of 22 Old 10-19-2015, 01:38 PM
Big Daddy's Avatar
Images: 38
Originally Posted by Johns04ZX10R View Post
Going off memory, the 600 linkage has a more linear ratio that is better suited for a single rider. The 1000 has a more progressive linkage that is designed to better support riding with a passenger. People used to say that the 600 linkage handles better around the racetrack. Personally I have never tried the swap. My bike handles perfect for me with the stock suspension set up right and a good set of tires mounted.
exactly. I too did the mod way back then with a DBL adjustable Penske and ohlins carts for the forks, once dialed in it was a much improved ride.
Big Daddy is offline
post #18 of 22 Old 11-03-2015, 10:34 PM
TrickKwak's Avatar
Which year zx6r knuckle is ideal to use? 03/04 636 or 05/06 636?
With the zx6r knuckle, are you also using the zx6r linkage bars or using the 10r gen1 original linkage bars?
2005 ZX-10r
post #19 of 22 Old 11-04-2015, 04:15 AM
Big Daddy's Avatar
Images: 38
I hope this dated thread answers your questions, if not do a seach of wstabbs threads as i believe there's more where this one came from.
Wstaab's 05 636 dogbone / rocker parts
Addendum: Once i purchased and performed the install of said parts it transformed the Gen1 from a tasmanian devil to, ummm lets say a tamed cougar. This setup is what the Hayden bros(tommy & RL) used on their respective race bikes that benefited them greatly during the race season.
post #20 of 22 Old 11-04-2015, 02:41 PM
I did it, because I ride solo, and Big Daddy's info made sense. I like what it did for me.
I ride old mountain roads, tight twisties/switch backs, and can be rough surfaces.
Big Daddy likes this.
louemc is offline
