Gen 4: 2011-2015 '13 g4; 81k miles and engine fail - Kawasaki ZX-10R.net
 19Likes
post #1 of 18 Old 06-12-2018, 09:03 PM Thread Starter
The Pace
scout's Avatar
Ran perfectly right until I heard a chatter noise and felt loss of power; not total loss; on CA slab, busy; no. 1 lane; traffic on right two lanes heard noise and nicely backed down allowing for me to target a safe place on right shoulder; waited for AAA tow.
I'll call Kawa dealer to set up drop off and will get back here with their report with details.
Bike passed 81,000 miles or very close to that figure; engine overhaul at 70500 miles. 2013 purchased new Sept. 2014 with extended warranty through Sept. 2019.
The bike ran the last 10k miles with pure beauty.
AAA was perfect in getting both the bike and myself home without feeling like an extorted victim.
scout is offline
post #2 of 18 Old 06-12-2018, 09:59 PM
bennice's Avatar
Again??
bennice is offline
post #3 of 18 Old 06-13-2018, 03:28 AM
renais's Avatar
Looking forward to the outcome of this warranty wise
renais is online now
post #4 of 18 Old 06-13-2018, 08:45 AM
bun1t's Avatar
There is nothing wrong with your Gen 4. It just needs a rider and some twisties
bun1t is offline
post #5 of 18 Old 06-13-2018, 10:38 AM
SkyDork's Avatar
Another one? Time to upgrade to the overweight Gen 5 with the improved engine.
rcannon, NinjaLife and turtle1000 like this.
#WordCrimes
SkyDork is offline
post #6 of 18 Old 06-13-2018, 06:54 PM Thread Starter
The Pace
scout's Avatar
Bike has just OVER 82,000 miles; so a little less than 12,000 after the rebuild.
Other observations: just before engine failure of the '11 g4 AND the '13 g4 the engine went into extreme SMOOTH mode; hard to describe as subjective.
OK
When my dealer tech released the '13 after the build, I immediately noticed the EXACT same super smooth engine I had prior to failure; so I was just a tiny bit nervous for a couple minutes prior to each loop for a couple days.
But np for 12 thousand miles.
Started this morning heard for first time with ear plugs, some disturbing chatter and shut off. Dealer gave me a go to bring it in; I also noticed that the front of the radiator appeared blackened; I suspect caused by the problem as I'm cleaning bugs, wheels and chain after each ride and always scan the radiator for damage as have had two radiator holes on each g4.
Certainly not rideable as the chatter without the ear plugs was disturbing.
Once I learn from tech guy I'll report back;
Also, for record, tank paint worn off in couple places about 75k miles; better than the '11; fork seals solid yet, '11 seals failed early about 30k; no oil burning but very MILD oil seepage after rebuild, nothing on garage floor and easy to clean off.
One other interesting observation concerning loop. Better tire wear. Part of loop that was extremely tight twists was closed by county due to storm repair in cliff section.
I had to learn a new tight section faster with more slab thus than the closed section; however with a fast mountain pass, slab, nearly empty, often with high winds (https://en.wikipedia.org/wiki/Califo...tate_Route_152) the bike responded perfectly without regard to whatever wind strength.
Rear met rr lasted 4k miles; front rs10 same with slight V. With old loop, 3k is max at the steel for rear and front V'd terrible at 4k miles
New loop is 40 miles longer but same time and better tire wear; about 230 miles; time ranging from 3 hours 15 to 4 hours depending upon conditions.
scout is offline
post #7 of 18 Old 06-13-2018, 10:16 PM
Schooley's Avatar
I would suggest buying twist of the wrist and reading x10000 times. Then repeat over and over.
Schooley is offline
post #8 of 18 Old 06-14-2018, 08:09 AM
I know better than to ask this, but I dont suspect there was an oil and filter change, after the rebuild, was there? It was only 12,000 miles.....
rcannon is offline
post #9 of 18 Old 06-15-2018, 06:27 AM
At 13,000 miles it should have been on about the 4th oil and filter.
ddipaola likes this.
cwrzx is offline
post #10 of 18 Old 06-15-2018, 07:08 AM
OMG Look at that squid!!
trackaddict's Avatar
Images: 51
Oil changes? HA HA HA
Because wheelie!!!
16' ZX10R - 08' Hypermotard 1100s
14' Ducati Monster 1200S - SOLD
13' RSV4-R - SOLD
My ZX10R's 11' - 08' - 07' - 05' - 04' - ALL SOLD
Miss my Black 04' the most!
Never enough money, never enough time!
trackaddict is offline
