13'-16' ZX6-R Stator Won't Fit? - Kawasaki ZX-10R.net
post #1 of 4 Old 05-26-2017, 02:34 PM Thread Starter
lenshead's Avatar
Hey All,
WHAT STATOR IS THIS?
I just bought a salvaged stator, supposedly from a 13 to 16 zx636, which according to all the references I can find, is part# 21003-0107, same as a Gen 4 Stator.
But I doesn't fit. It bolts in but is a few millimeters deeper. When I installed the stator cover, it locked up the engine.
Can the 6R use more than one stator type?
Thou Shalt Respect Thy 10, And Revel In It's Power, For It Is Good, And Plentiful.
lenshead is offline
post #2 of 4 Old 05-26-2017, 03:23 PM Thread Starter
lenshead's Avatar
As you can see, the (wrong) one has a much longer cable, but the connector fits the stock rectifier/regulator.
It's also deeper and has a different cable clamp. Wires are white, with black connector.
ID:	399210   Click image for larger version
lenshead is offline
post #3 of 4 Old 05-26-2017, 04:38 PM Thread Starter
lenshead's Avatar
Recommendations on new OEM vs. aftermarket?
Anybody?
lenshead is offline
post #4 of 4 Old 05-27-2017, 06:02 AM
GreenOne's Avatar
Can`t tell you what stator it is, but its probably not OEM for a 636. Looks like the aftermarket copies you find on ebay.
I would go OEM, and also did, but I see some people have had good experience with Ricks. (ricks not ricky)
I`m just in for the ride
GreenOne is offline
