05' zx10r falling on its face around 8k ?? HELP - Page 2 - Kawasaki ZX-10R.net
 2Likes
post #11 of 21 Old 10-28-2017, 01:33 PM Thread Starter
Ok I found a lil time to troubleshoot and doesn't seem to be missing on any cylinder , temps outta head was relatively close together... So next test was fuel pump, and not sure how to test pressure on it but tested flow rate and according to owners manual it's NB a bit short.. manual says 2.4oz (per 4 sec. Turn of key) and I'm under 2 oz and pressure although not measured seems weak, manual says 44 psi I believe, and mine was basically dribbling into measuring cup.. thinking about replacing pump but would like some suggestions or if this was normal... Thanks again
Jeradcarty is online now
post #12 of 21 Old 10-28-2017, 03:12 PM
Victors's Avatar
Replace it
2013 10R
2007 650R
2016 10R
Victors is offline
post #13 of 21 Old 10-28-2017, 07:54 PM
blink.'s Avatar
Spit on your finger to test the HOT exhaust pipes?!? Just spit on the pipe if you're going that route LOL.
It's your fuel pump, like I said it's common.
blink. is offline
post #14 of 21 Old 10-29-2017, 01:21 PM
Ghettochilds's Avatar
Eacth to their own ?
Ghettochilds is offline
post #15 of 21 Old 10-30-2017, 12:38 PM
Capncalyx's Avatar
Originally Posted by Victors View Post
Replace it
Rock over London, Rock on Chicago!
We will all die but only a select few of us will ever truly live.
..known Internet Suspension Warrior....And Plinko Master!
Capncalyx is offline
post #16 of 21 Old 11-01-2017, 10:35 PM
Stealth Rider's Avatar
I had the same issue. I can't find the thread but there was one saying to open up the kickstand switch because sometimes moisture gets in there and somehow causes it to freak out at 8k. The bike thinks the stand is down so it cuts the power. Open up the kickstand switch, clean it up, and see if that works for you. It was the weirdest thing I heard, but it was easy to give it a shot and it worked for me.
"The world is made of two types of people: riders and everyone else. In a country full of lawsuits, threat levels, child proof caps, rules and regulations, owning a motorcycle is one of the last ways to give the middle finger to society's expectation that we constantly be caged and protected. We all want our machines to be a representation of ourselves. Those that ride know being on a motorcycle is not just about getting from point A to B."
John Zamora - Super Streetbike
Stealth Rider is offline
post #17 of 21 Old 11-03-2017, 11:33 AM Thread Starter
Ok update!! Thanks to all first off and I replaced the fuel pump and test drove it yesterday, it seems to be fixed!! Tached on out when I hammered down on it and screamed. . Probably need to have injectors cleaned just by shape of fuel pump pickup sock but all is good , thank everyone for helping me solve this!!!
post #18 of 21 Old 11-03-2017, 02:18 PM
Capncalyx's Avatar
Ive used WitchHunter and ProFlow Technologies for cleaning injectors. Both were great, quick turnaround but ProFlow's overall service was better - even nicely #'ed my injectors by engraving for me since i put them in #'ed bags to begin with. Either way its 100 bucks.
gaz likes this.
post #19 of 21 Old 03-16-2018, 07:07 PM
Dude i got a 04 last week for 2700 and im having the exact same issue i cleaned filter k&n did exhaust servo mod ,plugs. I have no fi light. Im about to try a fuel pump
bigirb2002 is offline
post #20 of 21 Old 03-23-2018, 01:38 AM
Post Whore
-Op-'s Avatar
Fuel pump or side stand switch. Those are the typically the most common things that create this issue.
-Op- is offline
