***ZX-10R Owners please read...ESPECIALLY New Owners!!*** - Page 4 - Kawasaki ZX-10R.net
 10Likes
post #31 of 350 Old 04-27-2006, 12:59 PM
Post Whore
Sgtusmc96's Avatar
Good write up!
04 Green ZX-10R, Evo II Header, Evo Canister, PCIIIUSB, BMC Race Filter, Vortex adj. Rearsets, Scorpio Alarm, Scotts Damper, Ivan's TRE, Ivan PCIII USB Map, Ivan's Kleen Block-Offs, Clear Alternatives Flush Mounts, Puig Double Bubble, Mirror Blocks, Sho-gun sliders, 1/5 throttle, Hot bodies fender eliminator, Goodridge SS lines, pazzo shorties and exhuast hanger.
Sgtusmc96 is offline
post #32 of 350 Old 04-27-2006, 01:24 PM
BANNED
Abortions Suck's Avatar
Originally Posted by hillcountry10r
FIRST:
Why does my 10r bog down below 5K? Well for one we have what we call a close ratio tranny. To help keep you from wheelieing EVERYWHERE in first due to the min of 150RWHP. The 10r was never designed with pulling away from a stop light in mind. Yes, you may have to rev her up a bit to get her rollin.
Also she's geared high from the factory. this is to keep squids from loopin the bike as you pull out of the dealership parking lot. put a 16t on the front t will help this problem. Yes it will accelerate and wheelie easier. it will also run about 500rpms higher per the same speed.
while the spirit of this post is accurate, it isnt correct from a technical standpoint. if it was simply a matter of gearing the question would be 'why is my ZX10 slow in 1st gear?' as the gear ratio isnt variable and doesnt change no matter what the RPM reads. therefore there wouldnt be a 'bog' so much as an entirely slow gear. the reason the 10R bogs in the early part of the powerband is due to the cam profile and head/port design. they run a very short runner, with large lift cams carrying high duration. they also have large valves and ports (which have in the '06 been shrunk down to try and gain as much bottom end as possible.. i suspect that their valves weren't anywhere near their flow capacity at the point that their stock valve springs float.. therefore it was essentially power that cant ever be achieved on stock valvetrain, and as such they shrunk the valve inorder to pick up as much port velocity through the rev range and make real power as opposed to 'power that could be made.')
altering the gearing simply band-aid's the lack of grunt on the bottom end, it doesnt actually change the power delivery any. its just our solution to keeping the upper RPM HP figures, while still maintaining some driveability on the bottom end.
technically a 'close ratio' tranny would cause it to be MORE wheelie prone, what we have is called a 'long final drive.'
thought i'd correct this before it became a misconception, but like i said the spirit of your post was accurate.
Abortions Suck is offline
post #33 of 350 Old 04-27-2006, 01:28 PM
BANNED
Originally Posted by bonz
Awsome right up, rep on the way. Now we need to get the chromers and haters to get a long and we will actually be like a nice big Kawi family, with the added foster child. (GV, no offense.) LOL
only halfway.. she's half owner of my '06 ZX10.
post #34 of 350 Old 04-27-2006, 01:42 PM
10R
10R's Avatar
Excellent post Hill.
I don't care what kind of rider he was, he tested me and got dealt with. +1 in my book.
By: Riding4life162
10R is offline
post #35 of 350 Old 04-27-2006, 02:04 PM
PatrickG's Avatar
Images: 15
Originally Posted by danno22
Good write up Hill, Kawi should incorporate it into the owners manual
WTF!! This things comes with a owners MANUAL???????????????
PatrickG is offline
post #36 of 350 Old 04-27-2006, 02:17 PM
RickRoush03's Avatar
One more to add, IF YOU BITCH ABOUT YOUR GAS MILEAGE, GET A FUCKIN MOPED!!! This is a performance machine, not lawn mower engine!
"Lead, Follow, or get the hell outta my way!!"
Blue 2004 ZX-10R
- 152.5rwhp 77.6rwtq - more than I need
Red 2003 Jack ROUSH Classic #8 of 50
- 375rwhp 381rwtq
RickRoush03 is offline
post #37 of 350 Old 04-27-2006, 02:18 PM
bonz's Avatar
A new 06 and GV in the stable, you livin' clean or what? You've got some damn good karma!
bonz is offline
post #38 of 350 Old 04-27-2006, 02:19 PM
MonkeyBoy-UK's Avatar
AWESOME post hill..thanks \,,/
be a good idea to pin this topic without all the reply's lolol ?
MonkeyBoy-UK is offline
post #39 of 350 Old 04-27-2006, 02:33 PM
BANNED
Gixxer Vixxen's Avatar
none taken. i don't mind being hte redheaded step child :D
Gixxer Vixxen is offline
post #40 of 350 Old 04-27-2006, 03:19 PM
PatrickG's Avatar
Images: 15
There is another one that just came up....
600 mile service.....
How much does it cost?? And is it necessary???
PatrickG is offline
