Suspension setup 3gen 2010 zx10r - Kawasaki ZX-10R.net
 1Likes
post #1 of 16 Old 09-20-2012, 01:29 PM Thread Starter
ChrilleRR's Avatar
What setup should i use for track? rear and front suspension! 175lbs driver
I think front suspension is a bit hard but just guessing
ChrilleRR is offline
post #2 of 16 Old 09-20-2012, 02:47 PM
SkyDork's Avatar
There's no way for us to tell you over the Web. You're gonna have to go set the sag and play with the rebound/compression settings a bit to get the proper answer. There is no magic number.
First place to start though would be, what's your current settings? Do those settings feel good for you right now on the street? If so, why change them for the track?
#WordCrimes
SkyDork is online now
post #3 of 16 Old 09-21-2012, 02:22 AM
carlo_sg's Avatar
What SkyDork said...
However, I'm 175lbs in full gear and a suspension tuner said (for my gen3) it would be best to change front and rear springs, with stock suspension he recommended full stiffness at the rear. Front preload all the way out, and 1/4 turn back, stock rebound, and compression damping 13 clicks out.
carlo_sg is offline
post #4 of 16 Old 09-21-2012, 07:05 AM Thread Starter
ChrilleRR's Avatar
thx for info! i will check this with a tuner
post #5 of 16 Old 09-21-2012, 08:29 AM
vr6
www.racetech.com
I changed my rear spring and I am getting the fronts installed this weekend...
Just changing the rear spring I felt like I had a new bike...
Looking forward to getting the front springs installed
vr6 is offline
post #6 of 16 Old 10-17-2012, 09:39 AM
SpOoNpR's Avatar
Originally Posted by vr6 View Post
www.racetech.com
which brand springs are you using, i got a ohilins rear used from a memeber here. i was told by a friend my last track day i should change both front and rear that just the rear is not going to help me to much... been looking into it but the ohlins cartridge are around 1100 i cant seem to find any cheaper alternative... is there any other reliable brand avalible
SpOoNpR is offline
post #7 of 16 Old 10-18-2012, 07:59 AM
vr6
Blew my motor so I am not ridding a damb thing right now
I'm using racetech springs; had the rear sag set at 35mm for street. The front I did not get resprung yet.
The gen III has a soft rear spring, so the bike sits like a chopper and squats on acceleration so the first thing would be to change the rear spring.
I got this line from another memeber; "Your ecpectations should also be realistic in upgrading the springs. If you are not ridding hard now your not going to notice anything".
For me I was ridding so hard the bike would wobble like had low air pressure or something as I went through high speed sweepers. Also the rear wheel would hop around and not stay planted if the road got rough going through turns/sweepers.
After the spring install the bike was handling like it was on rails and felt planted... I'm way faster than a lot of guys I ride with. The guys who ride faster are on the edge...
Again, change the rear spring and see how that goes first. It's very inexpensive est. $175 total with install. ($99 spring 1 hour labor) Spring and labor may have changed since I've had mine done few years ago.
Tires help a lot too. I'm running Michelin 2CT set at 36 psi front 38 psi rear.
Good luck!
vr6 is offline
post #8 of 16 Old 10-18-2012, 09:20 AM
SpOoNpR's Avatar
Good luck!
thanx for the info bro.. im going to install that ohlins rear shock this weekend.. also order some dunlop 211 seem to be a very good tire for street/track rightnow i have a michelling Plt Pw in the front and the stock rear tire i think is bridgestone that comes frm the factory and i feel the rear hop and woble in some corners and i have the Bazzaz Fi TC not helping to much right now either for the bad tire combo or the rear spring... but we shall see, hopefully it will get better when i got it all that install.
SpOoNpR is offline
post #9 of 16 Old 10-19-2012, 12:34 PM
Poop's Avatar
FWIW, I used these as a baseline and adjusted from there. Obviously this is no replacement for having it done right top to bottom. http://www.sportrider.com/suspension.../kawasaki.html
Poop is offline
post #10 of 16 Old 10-19-2012, 12:40 PM
fireman69's Avatar
Get your sag setup and go ride the bike. Then tell us what the bike is doing good and more importantly what it is doing bad. then We can suggest adjustments on how to ure the bad.
I have worked with a couple of suspension tuners over the years and found this is the best way to work.
fireman69 is offline
