Pirelli Angel GT?? - Page 2 - Kawasaki ZX-10R.net
 4Likes
post #11 of 23 Old 05-29-2016, 02:25 PM
Post Whore
-Op-'s Avatar
Huh, I remember when the Angels first came out years ago, someone told me they felt bad. Sllid around a lot and no feedback. Have they made some changes to them?
-Op- is offline
post #12 of 23 Old 05-29-2016, 08:10 PM
Siwa's Avatar
Personally hate the Angel GT's. I've known 3 guys to go down on them as they just let go when pushed a bit too hard. They're a touring tyre with some twisties mixed in. I'd never trust them for proper twisties/canyon riding on a superbike.
2016 - ZX-10R KRT Winter Edition
https://www.instagram.com/superbike.turtle/
Siwa is offline
post #13 of 23 Old 05-30-2016, 03:23 AM
Post Whore
-Op-'s Avatar
This sounds more in line what Id heard about these tires. Mixed bag of thoughts.
-Op- is offline
post #14 of 23 Old 05-30-2016, 11:08 AM
mpp12's Avatar
Look T30 evo.... look no further....
Im running T30 evo on the back, amazing tire...
mpp12 is offline
post #15 of 23 Old 05-30-2016, 12:10 PM
jdgun_13's Avatar
Send a message via Yahoo to jdgun_13
The angels are not a sport tire, the tire profile is very flat although they give good feedback and OK grip are not nearly as good as the T30evo mentioned.
I run a S20Evo front & T30 rear on all my rides for the street more than enough for a 675R & panigale 1199.
WhatARush likes this.
jdgun_13 is offline
post #16 of 23 Old 06-09-2016, 11:07 AM Thread Starter
TheFantasticG's Avatar
Well, I guess I don't live around "proper twisties" and I definitely don't live around canyon roads here in Harris County, Texas. Nor do I think I'll be taking them to the TWS or MSR tracks... so...
I had a problem, at first, with them sliding... turns out when you have the PSI up to MOM spec, they will slide around. I dropped 5 psi, front and back, and they became a different tire that felt almost exactly like the Rosso IIs.
TheFantasticG is offline
post #17 of 23 Old 06-09-2016, 12:42 PM
zx7rr_2_zx10r's Avatar
I ran the Angel GTs on my Gen 3 until I sold it and never a problem with grip and they look pretty good too.
zx7rr_2_zx10r is offline
post #18 of 23 Old 06-09-2016, 12:50 PM
Judge Dredd Mod
mr_honez's Avatar
Never had any issues with the Angel GT's I ran on any of my bikes
BURNOUT.....
mr_honez is offline
post #19 of 23 Old 06-09-2016, 03:17 PM
White Fang's Avatar
I completely agree. You want any kind of decent edge grip you had better stick with a Dunlop Q3 or something similar. You can run the pressure a little higher with those, they are dual compound, as the rubber grips really well at road temperatures. I don't know what all you guys run, I am pretty light, about 144 pounds, on the track I run the Q3's at 29F/28R. Dunlop tech support said that was perfect for my weight, but not to go lower than 28F/27R and watch temperatures.
For the street what I'm seeing for any sane kind of riding, 34/39 is not bad for a medium-weight rider, grips well but you will get some longer life out of the rear. Maybe a pound less. Problem is if you do long stretches of freeway or open road they will get very hot even at those pressures.
Dunlop stated also that the 32F/32R pressures they list as a starting point for track use are for a 180-pound rider.
Not telling anyone what to do, but saying tire pressure is very important so take for what it is worth.
Sturm und Drang
White Fang is offline
post #20 of 23 Old 06-09-2016, 03:19 PM
White Fang's Avatar
Yes, just watch if you do long stretches of open road, you run the front that low it will get HOT, I promise. Hotter than the rear under some conditions as rear is much larger and can dissipate the heat better and is usually at a higher pressure.
Sturm und Drang
