Gen2 Rear suspension help - Page 2 - Kawasaki ZX-10R.net
 2Likes
post #11 of 19 Old 06-12-2017, 07:12 PM
Chris_1973's Avatar
It's the stock shock.
Shim the rear and get a racetech spring and adapter collar. It will help.
Chris_1973 is offline
post #12 of 19 Old 06-13-2017, 12:26 PM Thread Starter
Turbotalon4's Avatar
Thanks for verifying that it's stock. I shimmed the rear and I will play with the preload and compression and see what I can do with it
Turbotalon4 is offline
post #13 of 19 Old 09-19-2017, 09:50 PM Thread Starter
Bringing the thread back for a couple more questions. Ive been thinking about getting another rear shock possibly from something else like the gen 3 zx10r. This is a better shock no? Are there other options that could benefit my gen 2? I know there is always the ohlins etc but no looking to drop so much dough right now. Also Ive been asked if my front fork springs have been shortened. I was wondering if someone could verify this for me. Right now as the bikes sits from the bottom of the fork seal to the bottom of the tube is about 93 -94mm in length with the bike on its wheels. I know I could take out the spring and measure it but thats a lot of hassle. Also been thinking of getting the front forks revalved. Any good recommendations?
post #14 of 19 Old 09-20-2017, 10:39 AM
evallarta1's Avatar
Save your money on getting another OEM shock. The amount of hassle and time trying to make it work wont be worth it.
As to the front end shortened you have to take the forks apart to get the right answer. If the springs where "shortened" the rate changes and they would feel much stiffer. Best thing is to have them taken apart and inspected. Preload also affects where in the stroke the forks sit.
As to revalving the forks, I'd recommend (in no particular order) Ohlins, K-Tech and Bitubo. GP and Penske are also an ok option (in my opinion and experience). I'd stay away from Race Tech. The price and what you have to do to install them is not worth it.
Velocity Calibrations
evallarta1 is offline
post #15 of 19 Old 09-20-2017, 01:38 PM
Capncalyx's Avatar
Can you elaborate on that a little? I was pretty set on Racetech simply due to affordability... Not all of us can go out and blow a grand on a rear shock for a bike that may never see the track but from just hearing you and LDH talk it sounds so black and white - either blow $1500 on a nice piece or just stick with the stock trash lol.
NinjaLife likes this.
*Official winner of one Riflemans 1/5 insert
Also known to frequently drink and post.
Capncalyx is offline
post #16 of 19 Old 09-21-2017, 10:28 AM
GreenOne's Avatar
Although a terrible inaccurate method, mine is about 99mm if this helps you. With the bike on the side stand. Depends on your preload as mentioned. And also on stiction, where the fork rests.
Have you considered just respring for your weight and service what you have to see how it feels? Potentially 11 year old oil won`t exactly make the stockers do their best. Then you can save up for something better later.
I`m just in for the ride
GreenOne is offline
post #17 of 19 Old 09-21-2017, 07:33 PM Thread Starter
Well I replaced the fork seals about 5 years ago and put new oil in then. I thought about respringing the forks as well but I'm only 140. Shouldn't the stock springs be adequate for my weight?
post #18 of 19 Old 09-22-2017, 05:21 AM
GreenOne's Avatar
Ok. Shock needs service too, and probably time for your forks again. Stock fork springs might be a little too stiff, and rear a little too soft for you. It won`t be free as the shock must be done by a shop, but it`s probably a better option than trying to make something else work that won`t, and on top of that is already in need of service too.
GreenOne is offline
post #19 of 19 Old 09-30-2017, 11:28 AM
Uncle Snake's Avatar
I bought my Gen 2 with 15k miles on it and the stock suspension was so wasted that it nearly fell off the sidestand to the right. I have a 29" inseam and could easily flat foot both sides. As the manual said the seat height was over 31" I knew where the problem was.
Dealing with Dan at Traxxion for a complete fork revalve with their kits(not AK20), springs for my weight and track s/u including the labor was under $700. Adding a Penske 8393 s/u the same was another $800 or so. Best $1500 ever spent!
Go here if interested;
Axxion Compression Valves
Uncle Snake is offline
