Gen 4: Picked up a shock - Page 2 - Kawasaki ZX-10R.net
 4Likes
post #11 of 18 Old 02-24-2017, 10:10 AM Thread Starter
Originally Posted by evallarta1 View Post
Without really knowing too much about your bike, geometry numbers, pace, tracks etc I can only tell you that Bitubo shocks out of the box work pretty damn well. Short of messing with preload to get the bike balanced I really don't have to touch damping settings. In case you're lazy here are the stock specs.
Reb - 15 clicks out
Comp - 14 clicks out
HS Comp - 12 clicks out
Length - 307.5 mm
10kg spring at 12mm of preload.
Excellent stuff...I shall apply those settings and see how I get on.
Thank you.
10Arghh is offline
post #12 of 18 Old 02-24-2017, 04:46 PM
Carlos76's Avatar
When I bought my stock gen4, the first mod was Ohlins shock installed at stock length (309, no shim) and spring 110.
It ran wide everywhere. 5mm shim made holding line much better.
Just my 0.02.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
post #13 of 18 Old 02-24-2017, 07:05 PM Thread Starter
Just my 0.02.
That's good info...I heard about the shim trick. 8mm some people use.
Will check how I go and then try as an option maybe.
10Arghh is offline
post #14 of 18 Old 02-25-2017, 08:45 AM
evallarta1's Avatar
I'm setting up the geometry on a stock 2011 today, I'll post up actual measurements and where we go and why.
mpp12 and 10Arghh like this.
Velocity Calibrations
evallarta1 is offline
post #15 of 18 Old 02-25-2017, 08:47 AM Thread Starter
Hi evallarta1,
I am looking for a user manual for my Bitubo XXF31V2 shock, and was wondering if you knew how I could get hold of a PDF copy.
If not can you help me understand what all the controls in the picture are for.
Would appreciate any help.
Thanks.
10Arghh is offline
post #16 of 18 Old 02-26-2017, 03:23 PM Thread Starter
So Carlos was correct about the fitment.
The shock doesn't fit the standard linkage.
I believe the seller has supplied the wrong bushes (I think that's what they're called) for the stock linkage.
I will order the correct ones from the UK distributor this week
Pics:
10Arghh is offline
post #17 of 18 Old 02-27-2017, 10:59 AM Thread Starter
Just realised pics aren't showing for all so will attach to post.
10Arghh is offline
post #18 of 18 Old 03-01-2017, 08:42 AM Thread Starter
Errmmm....Don't try to install a shock upside down.
In my defense, the Bitubo sticker is upside down when the shock is installed correctly
Thanks for the service manual evallarta1
10Arghh is offline
Tags
shock
