Gen 2 06 rear shock swap zx14 - Kawasaki ZX-10R.net
post #1 of 3 Old 06-07-2018, 06:32 PM Thread Starter
ORSOM's Avatar
I've done a bit of research and it seems it's possible to swap out a Gen 2 rear shock for a zx14?
Can anyonw confirm this?
Zx14 shock will be perfect for my weight 80kg/175lbs and a cheap up grade.
ORSOM is offline
post #2 of 3 Old 06-09-2018, 04:20 PM
evallarta1's Avatar
Honestly, you could possibly be causing more issues than curing. Valving is going to be different and the 14r has a fairly stout spring compared to the 10r. A rear spring is about $120. Well worth spending that vs the time, frustration, and possible tires trying to make a 14r shock work.
Velocity Calibrations
evallarta1 is offline
post #3 of 3 Old 06-10-2018, 04:03 AM Thread Starter
ORSOM's Avatar
Thanks for the words of advise.
I was thinking of just changing the spring but thought the ZX14 shock and string was already suited to me.
I'll look for a spring with the right rating for 80kg rider.
Thanks again
ORSOM is offline
