cheap upgrade BPF - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By mpp12
  • 1 Post By Carlos76
post #1 of 5 Old 02-08-2017, 01:54 PM Thread Starter
mpp12's Avatar
cheap upgrade BPF
Since the BPF, in the gen4 are like black art or something..
my bike was 20K kms and I decided to change the oil, in the suspension... A FB friend recommended me the k-tech bushings, his experience was noticeable
FF slide bush** pair
44.70x20x1.50 (SBS-022)
FF guide bush pair
43x15x2.00 (GBS-019)
When we dismantled the suspension to my surprise the oem ones where coated like the k-tech, a bit worn on the side that is not coated but they seam OK.... anyway we changed the seals OEM, dust seals also OEM... and of course the ktech parts, new Repsol 5W oil...
we discovered that as soon as you take the parts apart there are a plastic part and a o ring that breaks, so we ordered...
put all together and at first in my house the suspension felt a bit just a bit softer so I went 1.5 click on the rebound clockwise..
the change is impressive, roads that the bike was hard to ride fast (hi speed road)because the road is not perfect (no matter the setting) now they are way more planted, a lot more planted, the damper was able to use it less hard.
on tight bends the bike feels more planted...
Im not a wana be racer, or a track guy that needs the best (I know that k-tech sells a full cartridge).... I just know that the suspension got better in the way it follows the road.
peterd10r likes this.
mpp12 is online now
post #2 of 5 Old 02-09-2017, 04:02 PM
Carlos76's Avatar
K-tech uses manufacturer NOK who supplies for japanese OEM, it can be that they are same for ZX10R. Found that K-tech asks less than my Kawa dealer for fork bush.
Looks to me that this white color o-ring must hold rebound oil pressure, not very strong design. I bet rebound of BPF on fork dyno shows inconsitent rebound damping.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
post #3 of 5 Old 02-09-2017, 04:30 PM
Carlos76's Avatar
Approach suspension like women: "As soft as possible, as hard as necessary."
renais likes this.
Carlos76 is offline
post #4 of 5 Old 02-10-2017, 07:34 AM Thread Starter
mpp12's Avatar
The plastic oring and the ruber oring, goes on the top of the fork.
mpp12 is online now
post #5 of 5 Old 02-10-2017, 07:42 AM Thread Starter
mpp12's Avatar
The OEM bushings and the K-tech where same dimensions but different materials or looked like it.
When we disassembled the forks this parts broke, remember first time in BPF.
mpp12 is online now
